Ok so everytime I shift and drop the clutch a bit faster there is a noticable clunk in the rear. If i shift and release the clutch slowly there is nothing. Now this only happens when I shift. When in gear and letting of gas and back on there is no noise. I know it's not the diff bushings as I just changed those and i also have a 1 piece DS installed so it's not a carrier bearing. It's a wied noise not like the worn diff bushings and it seems to be coming from outboard on each side. Possible wheel bearings or maybe worn diff? Any ideas as what to check first? Any help is greatly appreciated.
Faint clunk in the rear when shifting? - YlwPrlZTT18:14:50 01/15/14
